I'd like to create a line like that :
Is it possible? And how ?
Thanks for your answers!
The path to create new line types in Revit is through a dialog box that opens by the following menu.
In this dialog box you can only choose between dashes and points to make a line, so I would say that it's impossible to do such a line in Revit. Maybe (I didn't try it) importing a CAD, but I'm not sure.
Rodrigo Bezerra
Rodrigo is correct in that there is no direct way to create a complex Line Pattern in Revit. There have been many in the MEP field who have wished for this functionality to simulate pipes (i.e. ----G----G----G---- ). If you feel that this functionality is needed, use the link at the bottom of this post to provide your feedback to the support team. Be detailed and give examples, if possible.
The only way to accomplish this at this time is to create a Line-Based Detail Item Family and parametrically create the repeating symbol yourself. Attached is an example of such a Family (Revit 2013). Don't hesitate to ask if you have any questions!
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Rodrigo Bezerra
rodrigo.bezerra wrote:
"...I've already seen this solution of line based detail item for other application, but I personaly don't like it.
Let's face it: the very purpose of Revit is to use objetcts like they were "self aware" of their own nature and function. Every time we use shortcuts, we add some risk to the way the objects behave and interact."
Yep. That's why the first thing I mentioned was to provide feedback (via link) to the the Revit Support Team regarding this issue. The best chance of this getting implemented is though large quantities of requests. Realistically, though, I think the chances are low, regardless...
"...And very importat, Corey will probably correct me if I'm wrong: detail items work per view, so it won't interect with other objetcs throughout the model."
That is correct in regards to the direct use of the Detail Item Family. But, in some applications, the Detail Item Family can be embedded into a Model Family, and then the line will appear in all Views. This, of course, will not work for situations in which one does not have the option to embed it. For instance, Piping is a System Family and therefore cannot be edited, so one using such a Detail Item Family would have to manually apply this "on top of" the Piping. Definately not a good solution, there.
A line such as you show is seldom "nothing", rather it is meant to represent something "real". What is it? A fence? Then a railing might provide a more satisfying result.
A line based family does not have to be a detail item (2D), it can also be a generic model (3D).
A Repeating Detail could also provide the appearance you show (2D though).
Rodrigo Bezerra
