Revit Architecture
Revit Architecture
ca
New Member
ca
Message 1 of 6 (430 Views)
create a tag for a group, so I can add on Identity Data
430 Views, 5 Replies
10-03-2012 06:43 AM
does anyone have a suggestion on how this could be done?
thanks!
Alfredo_Medina
Message 2 of 6 (419 Views)
Re: create a tag for a group, so I can add on Identity Data
10-03-2012 08:48 AM in reply to: ca
I don't think that tagging a group is possible. As an alternative, you could select several items without grouping them, and save the selection (in 2013) with a name, which allows you to load or retrieve that selection later.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Employee
loboarch
Message 3 of 6 (406 Views)
10-03-2012 11:04 AM in reply to: ca
Groups can't be tagged but "assemblies" can.  You may consider making an assembly rather than a group and it may accomplish the same thing you are looking to do.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
rosskirby
Message 4 of 6 (381 Views)
10-04-2012 12:58 PM in reply to: ca
The only feasible option I've come up with is to make a special family called Group ID, which is loaded into the project and hosted in each group.  There is no geometry to the ID family (except a subcategory that I can turn on or off in my working and annotation views, respectively), so I just tag that family in the group, and that represents the group.
Sorry if that wasn't very clear.  Let me know if you need further explanation.
Ross Kirby
BIM Manager
Arcturis
CADastrophe
Message 5 of 6 (375 Views)
10-04-2012 01:11 PM in reply to: rosskirby
rosskirby wrote:
"The only feasible option I've come up with is to make a special family called Group ID, which is loaded into the project and hosted in each group.  There is no geometry to the ID family (except a subcategory that I can turn on or off in my working and annotation views, respectively), so I just tag that family in the group, and that represents the group."
That doesn't sound like a bad idea. To add to that, you can place the Symbolic Lines of the embedded 'Group ID' family on <Invisible Lines> instead of on a dedicated Subcategory (which requires constant on/off maintenance). You can still Tag the element even though it's invisible. And as long as you place the element somewhere consistent (like in the center of the Group), it won't be difficult to find. Anyway, it will still "glow" when the cursor hovers over it.
ca
New Member
ca
Message 6 of 6 (364 Views)
10-05-2012 02:47 AM in reply to: CADastrophe
I will immediately test drive a group with your good ideas and I hope to succeed!
Very grateful for your help!
Regards Christian
