Hi
I need to create a ground but I need to modelize every layers of the ground. Is there a way to do this?
I 'd like to do something like that but i want to modelize a biger area.
Thank for your answers !
Toposurface does not allow layers. From all Model Site instruments only Building Pad can have layers.
In this situation I would use a workaround.
I'll made an In Place Mass and then , a Wall by Face ( or Roof by Face) with layers declaired as terrain.....
I have attached a rough screen recording that shows how I've made it....
https://screencast.autodesk.com/Main/Details/51eb3160-27e2-475e-afaa-5c602e608ac9
The method does not allow variable width of layers and no terrain schedules....
Your Name
Just wondering if we could use floor command with layers inserted at the bottom having various thickness & materials. The floor can have varying surface by using modify sub elements option. attached a section view similar...you could get meterial schedule also...
