If you're already running 3013 on your Mac, I don't see why 2014 would be any worse. But better wait for an expert to answer.
That graphics card is not on the official list: http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112 But I will say, I personally used that Mac Book version for a while and Revit 2014 did run on it. However, NOT with Parallels. I strongly suggest that you partition your hard drive and install Windows in Bootcamp if you want to seriously run Revit on a MacBook.
Hello, hello
Thanks for answer. I will probably try the Bootcamp way-of-doing it with Revit on a newer iMac.
Then the specs would definitely be better than with my aging MacBook Pro.
Also - I am not satisfied with the stability and the speed of Parallels Desktop way-of-doing it, so I am looking forward to Bootcamp.
Harald
