Corrupted file
3 REPLIES 3
odette92
412 Views, 3 Replies
Corrupted file
When I open up my Revit file, it says that it is corrupted and that I should contact Autodesk Support? How can I retrieve my Revit file?
3 REPLIES 3
VWD-MLM
in reply to: odette92
Depending on what 'type' of file depends on the backup.........If it's a standalone rvt file, look for the backups that end with .0001, .0002....these numbers and sequencing depends on how often you accessed and and saved the rvt file.
IF.you have a workshared "central file", you can use the backup folder that goes with it and restored back to some time when you knew it was okay.....you'll need to create new 'local' files afterward tho.......
IF...workshared, AND the central is corrupted..........you can backup your local file.......and save as a new Central......same procedures as restoring Central files......just saving as a new central afterward and creating new local is ectra steps involved.
One other option that sometimes works for corrupt files....rather than open the file thru the Recent Files UI, go to Open>file>pick your file and check the audit box, and see what happens.  Can us this method with workshared also,,,,,bjust clcik on the Detach from Central box and click tha audit box when doing so..........if it can be salvaged, then again just save as new Central File and create new local(s).
HTH
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
jpemm
in reply to: VWD-MLM
@mike
What happens if the backup files ".0001, .0002" etc are also corrupted? Is there still a way of recovering that file?
Any help would be appreciated!
Thanks in advance
tim.winnington
in reply to: jpemm
Try this link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17680194&linkID=9243099
Otherwise you can send the file to Autodesk for hopeful recovery but that does take time
