Trying to open a .rvt file and it won't open. Error message say that data in file is corrupted and needs to be recovered. How do I manually recover?
Follow this instruction here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17680194&linkID=9243099
Hi i have the exact same problem, your link only takes me to a Revit search. was this the pun? or is there an actual fix>
hi, you may check it here. hope it helps. thanks
