Revit Architecture
2001jonathon
Message 1 of 14 (2,348 Views)
corrugated metal panels
2348 Views, 13 Replies
05-22-2012 02:31 PM
Hi everyone. Im really new to the whole revit thing and just need some help. I'm trying to put some corrugated metal on a wall in a small section, but I have no idea on how to do that. Just was wondering if someone can help me out on this.
Valued Mentor
vector2
Message 2 of 14 (2,332 Views)
Re: corrugated metal panels
05-22-2012 04:05 PM in reply to: 2001jonathon
First go into the materials UI. (On the manage ribbon).
Duplicate any material and give it a name for your corrugated metal.
Then give that name a corrugated metal appearance.
Back at your wall, activate the "split face" tool and draw the line
for the part of your wall you want this to be on.
Then with the "paint" tool, select that "name" for your panels
and paint that part of the wall you created with the split face tool.
Alfredo_Medina
Message 3 of 14 (2,321 Views)
05-22-2012 05:20 PM in reply to: vector2
It is not clear in the question if the user wants just the appearance of a corrugated panel or an actual 3d corrugated panel that looks correctly in elevations, sections, and 3d views.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Mentor
vector2
Message 4 of 14 (2,320 Views)
05-22-2012 05:38 PM in reply to: Alfredo_Medina
Good point Alfredo, and often we don't know the full extent
of someone's intent.
As for corrugated metal, I would think a bump image for that would
be most practical for construction representation. But you could
certainly model that panel if you wanted to.
2001jonathon
Message 5 of 14 (2,295 Views)
05-23-2012 06:10 AM in reply to: 2001jonathon
I was looking for the 3d model to show it, but if I cant get it to work then I guess the bump map would work as well.
parveen.revit
Message 6 of 14 (2,286 Views)
05-23-2012 07:41 AM in reply to: 2001jonathon
it is suggested that use jpeg image (bump map) for the 3d view and use 2d repeating detail for sections and details etc.
If you want to put this in 3d, it will create several issue such as door, window openings, duplicate inplace geometry etc.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Active Member
00jengland00
Message 7 of 14 (1,870 Views)
03-29-2013 09:03 AM in reply to: 2001jonathon
After reading the comments it seems that Revit cannot create a corrugated metal wall unless it is modeled as a generic model.  Am I correct?  I am wanting to model a wall with corrugated metal panel exterior/10" girt/interior corrugated liner panel.  Revit is currently unable to model walls with a corrugated profile...correct?  If so, perhaps I could get as close as possible with vertical reveals.  Any input would be nice.
Distinguished Contributor
cvandevere
Message 8 of 14 (1,863 Views)
03-29-2013 09:38 AM in reply to: 00jengland00
I used a horizontal lined surface pattern on the exterior wall and added reveals to the wall. When the building is rendered or in section it looks like corrogated metal.
CDV
constantin.stroescu
Message 9 of 14 (1,849 Views)
03-29-2013 12:30 PM in reply to: 2001jonathon
alttough in a project I prefer to use mapped bitmap in rendering an hatches in shade views, sometimes I use a real 3D.
  • New > Family > Generic Model Wall Based.....
  • on the Placement Side in Ref.Level , I draw first some reference planes for flexing purposes ,then Extrude
  • I draw a closed profile of a segment of the corrugated sheet and make the extrusion.
  • Assign parameters of offset,height, thickness...
  • Load into the project
Constantin Stroescu
BIM Manager AGD
constantin.stroescu
Message 10 of 14 (1,843 Views)
03-29-2013 12:48 PM in reply to: 00jengland00
for openings make an instance of the family  with a parametric void applied
Constantin Stroescu
BIM Manager AGD
