I have a situation with the drawing order of lines getting out of whack. For example, in some elevation drawings I have used the modify linework tool to lighten or thicken lines of object to give a better presentation. I have found when I do this that the line that is modified will be fully exposed, being drawn on top of objects that are in the foreground. Is there a command for modified lines of objects, similar to the "bring to front" or "send to back" command" that can be used with drafting work?
Scott Stolarczyk
