again, very nice Nic. Interesting to see how you used a void instead of
openings to get your detailing right. I don't know if this is still how you
work but in order to get your productionspeed up a little you should
consider to make some standard recangle, verticals, horizontals and
glass-sheets. You can load them in your family and save the family as a sort
of template - the preloaded items [nested families] can be adjusted in
length by a simple align [next copy you drag will automatically get the new
length]. You can also use other filling elements in this way.. have a go
with the families I attached.
Together with the method you show in this file you can make specific windows
in no-time...
"Nic M." schreef in bericht
news:41448e27_3@newsprd01...
> Its a revit 5.1 window. One of the first families I made. So it may be a
> litlle clunky
> I tried it and it still seems to work for me.
> You have to place it in one wall and then drag it to the exterior of the
> ortho wall
> See attach
> Nic
> "Bim Consultant" wrote in message
> news:4144504c_1@newsprd01...
> > Hi Nic,
> > Using, ur corner window family, does not subtract 2nd wall. 1 half of
the
> > window remains inside of the wall, any clue/workaround.
> > Thanks
> > "John" wrote in message
news:41406b3c_2@newsprd01...
> >> Does anyone know how to make a corner window family?
Attachment not added (content type not allowed): "Glas.rfa"
