Copyright symbol in Revit Text field.
9 REPLIES 9
Message 1 of 10
5187 Views, 9 Replies
There should be a way to get the Truetype font symbols into Revit. Right now
I open Word and click on Insert>Symbol and place symbol in Word doc,
highlight it and c to copy to windows clipboard and then switch to
Revit and start the text command and v to paste it in the text field.
Isn't there a more direct way?
9 REPLIES 9
Message 2 of 10
Have you tried the keystrokes for special characters?
Copyright symbol = Alt + 0169
From;
Edward Borg
Precision Drafting LLC
Http://Precisiondraftingllc.com
Message 3 of 10
Or, open up the Character Map and drag and drop your symbols in
"Cadkiller" wrote in message
news:4964226@discussion.autodesk.com...
From;
Edward Borg
Message 4 of 10
Steve_Stafford
Funny...timing that is...just posted a tip about this on my blog.
http://revitoped.blogspot.com/2005/09/are-you-special-character.html
Message 5 of 10
Alrighty!
wrote in message news:4964535@discussion.autodesk.com...
Message 6 of 10
Drag and drop doesn't seem to work for all symbols. Try dragging (R)
registered and notice it appears in the text box, but once you finsh the
TEXT command it gets converted to some funny stuff â. Any idea...
"AlmightySR" wrote in message
news:4964399@discussion.autodesk.com...
From;
Edward Borg
Message 7 of 10
Steve_Stafford
Which font are you referring to? Are you sure you've got the same font selected? It is easy to browse the wrong font and try to use a symbol from its collection.
Message 8 of 10
m.viall
When I am trying to modify text notes, the © symbol gets inserted, but is not visible.  When I search for the symbol throughout the drawing it is visible, but in the text notes field it just creates a space instead of the symbol.  Any help would be greatly appreciated.
Message 9 of 10
parveen.revit
in reply to: m.viall
it may have something to do with font or font color. plz check
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Message 10 of 10
danbush
When you insert from another program such as word, the correct symbol will appear but once you click off it, the symbol reverts back to the character from the text style of the text block.  If you duplicate the style or edit it to use the correct font for the symbol you want (such as wingdings, etc.), it should work then.
Rail Community
