CopyRasterRegion Failed: line 464 of Source\GImageRendererOGS.cpp
1 REPLY 1
kahchun.ho
469 Views, 1 Reply
I have a workset drawing and out of sudden, when I tried to open the file, it crash and keep asking me to choose a different view. Checked on the journal file, and found the error but not too sure what is the cause. Please advise.
I attached the journal as reference.
'E 23-Aug-2012 12:20:34.684; 0:< Jrn.Activate "[UCTI_Campus superstructure_Jacob forsberg(Recovery).rvt]" , "Floor Plan: DO_Aras 4" ' 1:--Post event status Succeeded ' 0:< View Open: Element expansion used 2.799698 seconds averaging 0.000063 seconds/hit for 44753 hits. ' 0:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits. ' 0:< CrsTimer event occurred for 1 times in DesktopMFCView [Floor Plan: DO_Aras 1] ' 1:< DBG_WARN: CopyRasterRegion Failed: line 464 of Source\GImageRendererOGS.cpp. ' 0.986609== 1:<<<;PERF;MISC;drawing 'C 23-Aug-2012 12:20:35.804; 0:< Display exception has occurred. 'C 23-Aug-2012 12:20:37.666; 0:< ADialog::doModal start 'E 23-Aug-2012 12:20:39.122; 0:< Jrn.PushButton "Modal , Views , Dialog_Revit_ViewsListOnly" _ , "Cancel, IDCANCEL" 'C 23-Aug-2012 12:20:39.139; 0:< ADialog::doModal stop 'E 23-Aug-2012 12:20:39.150; 0:< Jrn.Browser "Activate" _
Tags (2)
1 REPLY 1
eric.stimmel
in reply to: kahchun.ho
I have seen a similar warning in the journal file... this was followed by a screen flicker and a graphics driver crash. I'm not sure what it means, but hopefully someone with more knowledge will comment on this.
 'CT [Modify | Section Boxes]:
 '	{1} spacer_shr
 'Cache:
 '<<End build CT>>
 ' 0:< DBG_WARN: Raster::Map Failed: line 488 of Source\GImageRendererOGS.cpp.
Rail Community
