I created a floor at the second floor and then proceed to copy multiple times to the thrid and fourth, while in the building section. I found that the the floor slab at the thord and fourth levels do not clean up with the intersecting walls.
Am I overlooking a set or setting?
Maybe you need to select the walls and do one of these two things:
1) Top constrain = Level 3 (or Level 4) & Top offset = - (the thickness of the slab)
2) Attach --> the slab
