I am trying to cut and paste simple line work, but it wont paste into the new drawing. Everything disappears when I place it.
Do you get any messages from Revit when you try this?
I've found that if you want to copy/paste annotations like linework or text an easy way to get it to work is to place an actual 3D object near it and then grab all the annotations along with the object and it will let you copy and paste everything. Then you just erase the object. Don't know why it works but I've been using this method since R13.
check that your not pasting items onto a workset that's hidden in the view your on.
