Copy Monitor Question
2 REPLIES 2
373 Views, 2 Replies
I am trying to Copy Monitor lighting fixtures from the Electrical model to my Architectural model. I started with Copy Monitor the Level as suggested by Revit. However, when I Copy Monitor the fixtures over, they all came in @ 0' elevation (offset from the Level). The original fixtures in the Electrical model are @ 9' elevation (offset from the Level). Of course, I could manually change the fixture elevation but it would defeat the point of Copy Monitor, wouldn't it? The fixture families are not face or ceiling based, but workplane based, if that matters. Any thoughts how to deal with it? Thanks.
2 REPLIES 2
alan.quinn
in reply to: ToanDN
Try the following: Deleting the copied levels, and re-copy/monitoring should fix the issue.
Thanks foe posting.
in reply to: alan.quinn
Thanks for replying. I have tried that and the lighting fixtures are still coming in on the wrong elevation. However, when I copy monitor the diffusers from another linked model (from the same consulting firm) and they all are coming in on the correct elevation. Attached is a side-by-side screenshot of the property a lighting fixture and a diffuser.
