Revit Architecture
0 Kudos
Post 1 of 2
Copy / Moniter Walls
116 Views, 1 Replies
12-06-2012 11:14 AM
I have a model which has an Architectural Model linked in.  I have successfully Copy/Monitered the Levels and Grids.  However I am having trouble doing the same for the Walls.  During the Copy Moniter process I can select the walls and the system seems to recognize the selection.
However, when I exit the copy tool I cannot select the walls or add a wall hosted element.
HELP???
There's a separate "Finish" button on the Options Bar for selection that you must hit prior to hitting the larger "Finish" to exit the Copy/Monitor function.
If this isn't the cause of the issue, just let us know!
1,007 Kudos
Post 2 of 2
Re: Copy / Moniter Walls
12-06-2012 11:27 AM in reply to: jfitz2020
