Revit Architecture
kai.alaska
Message 1 of 7 (852 Views)
Copy/Mirror Stairs
852 Views, 6 Replies
11-09-2010 11:11 AM
I have stairs in a group, and have mirrored the group. The stairs do not create when I mirror this group, and I get this error.
"Couldn't generate surfaces for stairs."
I have tried removing the stairs from the group, and copy them, and they mess up with this error:
"Highlighted lines overlap. Lines may not form closed loops."
These stairs are in a quadplex, and are exactly the same in each unit. Is it not possible to copy stairs? or mirror them? Do they need to be created individually?
Product Support
alan.quinn
Message 2 of 7 (846 Views)
Re: Copy/Mirror Stairs
11-09-2010 01:03 PM in reply to: kai.alaska
You should be able to mirror, copy, rotate, etc. the stair. See the below link (short video with no sound)
http://www.screencast.com/users/AlanQuinn/folders/Jing/media/eb77d366-116b-4bf3-9567-ecdc4ae74e89
I created the first stair and added a few Reference Planes to Mirror the Stair around, but you can use anything a mirror point. In the past I have used wall, furniture etc. Copying can get tricky as you have to make sure you pick up everything, but it’s also possible.
Hope this helps,
Alan Quinn
Support Specialist
Product Support
kai.alaska
Message 3 of 7 (840 Views)
11-09-2010 03:18 PM in reply to: alan.quinn
I continue to get errors when I try to Copy or Mirror my stairs as long as I have the stringers left and stringer right properties set to 'closed' .
As soon as I changed those stringer properties to 'none' or 'open', I am able to copy/mirror at will.
Valued Contributor
augidomeo
Message 4 of 7 (818 Views)
11-10-2010 03:31 AM in reply to: kai.alaska
Dont thinking 3d modeling,
Think that you are building,
Thanks the Revit programmers
Please see my stais case
dotuanhanh.blogspot.com
Product Support
alan.quinn
Message 5 of 7 (791 Views)
11-11-2010 07:05 AM in reply to: kai.alaska
I tested “none” and “open” and was still able to mirror. Can you upload a copy of your file and I’ll take a look at it?
Alan Quinn
Support Specialist
Product Support
kai.alaska
Message 6 of 7 (782 Views)
11-11-2010 10:04 AM in reply to: alan.quinn
Alan,
Do you have an email I can send this file to?
Product Support
alan.quinn
Message 7 of 7 (762 Views)
11-12-2010 10:53 AM in reply to: kai.alaska
Please post it here of drop it in Dropbox and send me the link.
Thank you,
Alan Quinn
Support Specialist
Product Support
