Copy/Mirror Stairs
6 REPLIES 6
kai.alaska
3301 Views, 6 Replies
Copy/Mirror Stairs
I have stairs in a group, and have mirrored the group. The stairs do not create when I mirror this group, and I get this error.
"Couldn't generate surfaces for stairs."
I have tried removing the stairs from the group, and copy them, and they mess up with this error:
"Highlighted lines overlap. Lines may not form closed loops."
These stairs are in a quadplex, and are exactly the same in each unit. Is it not possible to copy stairs? or mirror them? Do they need to be created individually?
6 REPLIES 6
alan.quinn
in reply to: kai.alaska
You should be able to mirror, copy, rotate, etc. the stair. See the below link (short video with no sound)
http://www.screencast.com/users/AlanQuinn/folders/Jing/media/eb77d366-116b-4bf3-9567-ecdc4ae74e89
I created the first stair and added a few Reference Planes to Mirror the Stair around, but you can use anything a mirror point. In the past I have used wall, furniture etc. Copying can get tricky as you have to make sure you pick up everything, but it’s also possible.
Hope this helps,
kai.alaska
in reply to: alan.quinn
I continue to get errors when I try to Copy or Mirror my stairs as long as I have the stringers left and stringer right properties set to 'closed' .
As soon as I changed those stringer properties to 'none' or 'open', I am able to copy/mirror at will.
augidomeo
Dont thinking 3d modeling,
Think that you are building,
Thanks the Revit programmers
Please see my stais case
dotuanhanh.blogspot.com
alan.quinn
I tested “none” and “open” and was still able to mirror. Can you upload a copy of your file and I’ll take a look at it?
kai.alaska
Alan,
Do you have an email I can send this file to?
alan.quinn
Please post it here of drop it in Dropbox and send me the link.
Thank you,
