Coping to top of Parapet Wall
1 REPLY 1
2471 Views, 1 Reply
I'm looking for a way to place a concrete coping to the top of a (level) parapet wall. I cannot find any such family in the library, but being new to Revit I may be looking in the wrong area, or using UK terminology. Any guidance please? On a similar vein, at the other end of the wall, is there a Foundation (sometimes called footing) family, so that the structure is represented correctly in sections? Thanks Damian
1 REPLY 1
1. You can either design the coping into the wall family using a wall sweep. Or you could create a hosted sweep on just specific walls. The tutorials have a good exercise for learning how to do this. 2. For foundations you can use: A short fat wall. A wall sweep. A hosted sweep. A floor. Much depends on the construction details of the project. "Damian Bree - BDP" wrote in message news:409e0cbd$1_2@newsprd01... > I'm looking for a way to place a concrete coping to the top of a (level) > parapet wall. > > I cannot find any such family in the library, but being new to Revit I may > be looking in the wrong area, or using UK terminology. Any guidance please? > > On a similar vein, at the other end of the wall, is there a Foundation > (sometimes called footing) family, so that the structure is represented > correctly in sections? > > Thanks > > Damian > >
