Yeah, I knew we could do that, I was looking for a fix that would be
transparent. Easy enough to use a intermediate file and have the exported
attached at a scale and periodically delete all and copy from the reference
in place.
It would be no problem to do as you suggest, but the person requesting wants
a "effortless" export so they don't have to tweak the files. Not my choice.
We have a need to produce models, that Revit can easily do, and export them
to DGN for use with PDS(Intergraph Plant Design), and it wants "12:2032"
rather than "12:8000".
Thanks though.......
"Steve_Stafford" wrote in message
news:12750823.1078877677085.JavaMail.jive@jiveforum2.autodesk.com...
> We export to DGN, reference the export into a seed file, then merge the
reference. This forces the seed files settings onto the Revit export. The
dgn Settings file option when exporting does not work, it is broken.
> We have not ever done export to 3D however, only for background 2D data.
I imagine that using a 3d seed file should yield similar results however.
> HTH
