When I am setting the plot sheets I have to switch off Sections and section boxes, Ref planes, window tags, door tags or planting, objects that or not required in views. I seam to do this quite a lot
Is there a way to set the state drawing so that at the things you want switched off are or if needed go back to how it was before
Thanks Martin
make a View Template from a Duplicate View , swich off all you don't want to appear in your final drawing and then apply the View Template to all the Views you want to plot.
detailed description:
Thanks!
Ihave looked on you tube your sulution is great I will spend to night getting it working
thanks for time in replying, Martin
