Revit Architecture
octavio2
Message 1 of 6 (646 Views)
Contour lines - can they be turned off?
646 Views, 5 Replies
10-20-2012 09:52 AM
I have a site plan and also a 3D view in which the contour lines show.  When I try to hide them, then the ground surface also disappears and the footings of the building show.
will like to know if I can just turn the contour lines off from my views (inlcuding the 3D) without affecting the anything else like the visibility of the site and of the ground and of the exterior uneven sloped surfaces.
 Is there a way or setting that you could advice? (I assume that there is a buttom there somewhere that I haven't discovered yet).
Thanks in advance.
VG > Topography > Primary Contours, Secondary Contours...
Alfredo_Medina
Message 2 of 6 (643 Views)
Re: Contour lines - can they be turned off?
10-20-2012 10:20 AM in reply to: octavio2
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
octavio2
Message 3 of 6 (635 Views)
10-20-2012 10:35 AM in reply to: Alfredo_Medina
Thanks, Alfredo, it worked.
I am trying to correct certain things of a site that I have been working with for a long time.
On the 3D view of the building and the site, which I have in Hidden Line, all the trees show a rond base like if there is a mount or mulch under them.  It is not a big issue, but I also wonder if that round  base could be turned off.  I tried Planting in VG and turned off "Hoidded Lines", but nothing happened, so it seems that the round base is controlled by something else?
Alfredo_Medina
Message 4 of 6 (631 Views)
10-20-2012 10:41 AM in reply to: octavio2
The tree is a family. Therefore, open the tree family, and modify it.
octavio2
Message 5 of 6 (622 Views)
10-20-2012 11:25 AM in reply to: octavio2
Thanks, Alfredo.
Alfredo_Medina
Message 6 of 6 (616 Views)
10-20-2012 11:32 AM in reply to: octavio2
No problem.
Please remember that the post that should be marked as the solution is the post that includes the solution, not other posts with comments in the same thread.
