Hi there.
I have basic contours setup. When I draw the label line through the contours the result is not what I'm expecting. As you can see from the attached, I have contours set at 13000 as the high point and at the edge of the topsurface and, likewise, 10000 as the low point and at the other edge of the topo surface. Why aren't these elevations coming up on the contour labels?
Many thanks
Marty
Solved by GHASEM_ARIYANI. Go to Solution.
Hi
Button on Click on the Site settings The values To change.
Maybe your problem is solved.
Thanks gh_ar. I've tried various settings without success. Not sure if this will work but attached the rvt file.
https://docs.google.com/file/d/0ByurucMZF-2ea1JaWHB3Nlc5cGM/edit?usp=sharing
thanks again.
Thanks for your posting. Please try to change the Site settings from Massing & Site > Model Site.
Also label will be placed for the intervals in the topo, hence at the very top level (13000), label will not be displayed. If you want to put the label at the top, maybe you could use spot elevation?
For further information please refer to the link:
Hope it helps.
