Construction As-Built model / Multi-Discipline Coordination Questions
4 REPLIES 4
andersonst
1193 Views, 4 Replies
Hello all,
I am seeking advice on how to begin creating a construction model. I am relatively new to using revit making this a bit of a challenge. On the project I am currently working on I am recieiving updated models from the Architect as they make changes to their model, however their model as a whole is not truely accurate and many construction details/information is left out. I have currently branched from the latest Architect model and I have began reviewing the model to insure its accuracy with the intent of updating the model for every ASI that comes out. I ran into a lot of issues getting the model going. Worksets created the bulk of the issue as the model was saved with worksets and i do not need them as i will be the only one in the model. I ended up having to remove them from central and relink the files after saving. A level of BIM has yet to be established from the owner. I also am recieving CAD Files from MEP, and Structural Steel, so I will be removing many files that are currently linked into the model from the architect replacing them with "as-built models". I found a lot of good information online, however most of it didn't quite apply to my unique situation. As of now it looks like i will just be diving in and getting into the model to insure its accuracy. If anyone has been in this situation or has any advice that would be very helpful. But for now here are some of my main questions:
- How do i go about establishing what level of model we can create?
- The information I have found on BIM Levels is very vague. What exactly do i need to include in a Level 4/5?
- Is it efficient to create a seperate model to create a seperate construction model?
- Many things are detailed but not actually modeled, this is ussually because they are time intensive and extremely difficult to do. Do i need to be modeling all of these items?( Falls into the what exactly is required at each Level question)
 - How do i track and insure that my model is accurate/ up to date? I noticed I have caused other issues editing new issues.
I really could list these little questions for days. Unfortunately a lot of the information i have found is too vague or too big picture and doesnt get into the nut and bolts like I need.
4 REPLIES 4
andersonst
in reply to: andersonst
I also am running into an issue with doubling up in the models.
Ex: I have a Architectural and Structural model linked together and they both have structural walls modeled.
Do I delete one?
Do i just need to start over on this project and rebuild everything from scratch?
I think it would be much easier to rebuild and start from scratch, however a lot of the modeling that was done is over my skill level and It would take me a very long time.
engr_mondo
"...for every ASI that comes out" What do you mean by an ASI?
Mondo
engr_mondo
Try to start checking/using your company's BIM workflow/strategy--for sure every work required in creating an As-Built model are documented. Use the received models from architect and drawings from MEP as reference only--to be linked.
Mondo
andersonst
in reply to: engr_mondo
By ASI I mean architectural supplement instruction.  Basically anything that changes the contract documents or clarifies them. Unfortunately the workflow strategy is where I am having the most trouble. I am unable to find any good resources for the perdiciment I am currently in, because the workflow/strategy was not established early on. I also am having a hard time finding a really good resource for setting up the BIM Flow, everything I have found is very vauge, I currently am planning on pulling everything together in Navis works to create the As-built Model to present to the Owner.
