I'm creating fairly complex curtain wall units and have issues where some of my components respect the constraints while in the unit family, but not in the project. For example, in the attached MMSS_0_0_C (Finial+Pilasters) TEST2.rfa file (a very stripped down version, the two objects on the left have thier refererence points locked to the Left and Front reference planes. The same goes for the objects on the right. When the Left or Right reference planes are moved, the family flexes properly. In the attached ProjectCW.rvt file, the family replaces one of the glazed panels. I changed the Mod Width parameter to match the distance between vertical grid lines and 3 of the 4 vertical objects adjust properly. The fourth remains outside of the panel area. This object is also tied to the proper location with locked dimensions to no avail. Any Idea why this one object respects the constraints in the family but not in the project?
Jon
i replaced all generic models in the family with sweeps
now the family follows the grids in the project
regards,
Coen
