constraining wall types
1 REPLY 1
vigneshkaushik
195 Views, 1 Reply
how to constrain a set of walls to all be of the same type? If i change the type of one wall, all other walls should automatically reflect the change as well. Is this possible in revit 2013?
1 REPLY 1
LisaDrago
in reply to: vigneshkaushik
Hello and Welcome to the Discussion!
I do not see a way to accomplish this.
I will say it is quick enough to select the walls that need to change and change them in the type selector all at once.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
