how to constrain a set of walls to all be of the same type? If i change the type of one wall, all other walls should automatically reflect the change as well. Is this possible in revit 2013?
Hello and Welcome to the Discussion!
I do not see a way to accomplish this.
I will say it is quick enough to select the walls that need to change and change them in the type selector all at once.
LD
