Solved by constantin.stroescu. Go to Solution.
try these:
Constantin Stroescu
Is it possible to do this in Revit LT 2014, or is there another way to connect steel members? Most of the advice is for full Revit which I don't have. Thank you in advance.
You can try to do it manually by using Opening by Face:
Constantin Stroescu
