Concrete sunshade with plaster finish
9 REPLIES 9
Message 1 of 10
josemukalel
2890 Views, 9 Replies
Drawing1-Model.jpgI am trying to model Concrete sunshade with plaster finish but still not success,please help me  to do this .i choose fascia but not happy with this detail.please see the image
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
9 REPLIES 9
Message 2 of 10
VWD-MLM
in reply to: josemukalel
I'd use a Line or Wall or Face-Based Family with parameters and
materials.....gives a lot of flexibility..
Mike
Michael L. Maloney
Proj/BIM Manager
Blue Ridge Architects - CLT
13850 Ballantyne Corp. Place
Suite 500
Charlotte NC 28277
386-931-6733 Cell
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
Message 3 of 10
Lucavox
You could do this in different ways, all valid.
- Custom Architectural column family
You could create a family based on line with the profile you need. Drawing it as Architectural column the finish will be placed around it.
- 2d Annotation
Create the 3d model without the finish and add it to the section with the 2d annotation tools
These are just two ways to do this, you could invent new ones.
Message 4 of 10
josemukalel
in reply to: VWD-MLM
Can you please explain by some image .i didnt get your answer because i am still new to revit
Jose George
+64 22513 0828
Message 5 of 10
josemukalel
in reply to: Lucavox
Capture22.PNGI want to see in section and wall section with plaster finish not only in callout(detail)
Jose George
+64 22513 0828
Message 6 of 10
Lucavox
This is a custom family based on line. to do this:
- create a new family and select the template "Metric generic model  - line based"
- create 2 sweep: One for the concrete and one for finish
- Create two material parameter for the concrete and finish
- Load the family in the project and place it inside a wall
- You need to set the finish material of wall equal to the finish material of your custom family and joining the two elements the result will be this:
If you are a new user of revit it's not simple but not impossible, please try googling for revit family tutorial.
Kind regards,
Luca
Message 7 of 10
josemukalel
I use generic model wall based with 2 sweep and 2 material parameters.is this way good or it will get problem in schedule  ?Capture111.JPGCapture122.JPG
Jose George
+64 22513 0828
Message 8 of 10
Lucavox
If you create a material take off you should have the correct quantities.
Be sure to make the wall and the component joined.
Luca
Message 9 of 10
loboarch
This could also be done as part of the wall family itself.  I was able to add 2 profiles (1 for the concrete inner piece and one for the plaster wrap) and position them in the structure of the wall to get the condition you are looking for.  This method might be of use if you have a lot of walls with this condition, because the shade is part of the wall itself rather than different family elements placed on the wall after the fact.  Both methods work but one may be better than the other depending on the context of what you are doing.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 10 of 10
elson.hutomo
in reply to: loboarch
Hello, i,m really new to Revit and just started my first project. Got the same issue here and i'm interested on how you did the concrete sunshade. Can you teach me or make a video step by step with it? Really need help here.
