Using Revit Arch 2013, I'm trying to make a small landing at the top of a concrete ramp. I created a mass (shown in the screenshot) that represents the 'tweaking' transition from the top of the ramp (flat) to the floor which slopes at 2%.
If I try to crete a mass floor it bases it on a level, which can't create the warped top surface. I tried modeling an in place component (not using massing) but don't have near the flexibility with that - couldn't pick certain faces as work planes, couldn't use 3d snapping, etc.
How do I create a simple 4" think concrete landing with wardped top surface from this?
Thanks.
Solved by constantin.stroescu. Go to Solution.
My opinion is that you can use succesfully a Floor with a Shape Editing applied:
Your Name
