Conceptual Metric Mass: Rotating or copying a mass
0 REPLIES 0
Message 1 of 1
297 Views, 0 Replies
Hello!
I am working with revit's conceptual mass template to create a model. I have made work planes, to create model lines into them and then obtain the masses for my model with "create form".
My question is: If all of the masses I need are the same, let's say, I have made a workplane with a singular shape and this could be the mass I need that'll work as four walls: Is there a way I could copy and rotate this mass? Or do I have to actually model the same shape inside my other workplanes, and then work on all of the masses individually?
I attached a screenshot.
Thank you.
-M
0 REPLIES 0
