I have a curved mass mesh that I need to use to drive a series of hanging bottles that hang from a curved (wave form) ceiling. See Attached Image.
The problem is that the adaptive curtain panel objects (which are the hanging bottles) maintain a square to the surface orientation. We need them to be plumb, or square to the ground and not the mass (ceiling) surface. In reality they will be hanging from the ceiling.
I don't see a way to get this orientation to work. Is there any method to accomplish this need?
Solved by Alfredo_Medina. Go to Solution.
No need to create the bottle as a panel. In Revit 2013, you can create this with the new Divide & Repeat feature. Check the Wikihelp for more information about this feature.
