I am using revit 2012 and need to create a curved (2 way curve) curtain wall. I used conseptual mass to create the basic form and then applied a divided surface, checkered triangles. Then I applied my custom triangle with the structure modled to create the basic gridshell. I would like to be able to create a drawing in my project that lables each triangle and relates it to the schedule as each triangle is slightly different. how do I go about doing this?
In the project, you can schedule pattern-based curtain panel families as follows:
1. Apply your curtain panels to your mass divided surfaces, load mass family into project.
2. View > Schedule > Curtain Panels, select desired fields > OK
3. This should generate a Panel Schedule, and by default, list each panel family in use.
Pattern Component Family WikiHelp documentation below:
Thank you,
