Revit Architecture
Revit Architecture
octavio2
Message 1 of 10 (3,051 Views)
Computer wiht both Revit 2013 and Revit 2014 will work OK?
3051 Views, 9 Replies
04-24-2013 05:00 PM
Will a computer that has both Revit 2013 and Revit 2014 installed at the same time work well?
Will each of the versions work well when run without any glitches? (Assuming that only one of the versions will be open to work with at any one time).
Thanks in advance.
edwin.prakoso
Message 2 of 10 (3,022 Views)
Re: Computer wiht both Revit 2013 and Revit 2014 will work OK?
04-24-2013 09:00 PM in reply to: octavio2
I have them both on my computer. And they both work fine.
Just remember to install update release 1 and 2 for Revit 2013. Revit 2014 will install .NET Framework 4.5 as prereq and it will cause some problem to Revit 2013.
The updates will fix it.
If you need the links:
Ribbon hotfix for Revit 2012
Revit 2013 Update Release 1
Revit 2013 Update Release 2
Revit Architecture 2013 Update Release 1
Revit Architecture 2013 Update Release 2
Revit MEP 2013 Update Release 1
Revit MEP 2013 Update Release 2
Revit Structure 2013 Update Release 1
Revit Structure 2013 Update Release 2
Kind regards,
Edwin Prakoso | www.cad-notes.com | @CADnotes
If this post solve your issue, please mark this post as solution. It will help others who have the same issue to find solution.
Active Contributor
M-Town_Drafter
Message 3 of 10 (3,018 Views)
04-24-2013 09:07 PM in reply to: octavio2
I have Revit LT 2013 and 2014 both installed.  I had them both up and running at the same time, just to compare performance, check for differences in the UI, etc.  I don't think that the full versions of Revit would tax hardware much more than the full versions.
As a side note, I tried uninstalling Revit 2011 last year, as I thought 2 versions (2012 and 2013) would be sufficient.  Created quite a mess.  Just in case you were thinking about getting rid of 2013...
Active Contributor
tarheels09
Message 4 of 10 (1,851 Views)
09-12-2013 08:15 AM in reply to: edwin.prakoso
Not that I don't believe you about the updates. But can we get an answer from Autodesk on this?????
We have 2012 and 2013 and are ready to install 2014.
Active Contributor
M-Town_Drafter
Message 5 of 10 (1,835 Views)
09-12-2013 10:40 AM in reply to: tarheels09
Well, I'm actually still seeing the occasional ribbon issue, the one where the correct contextual won't show up.  Not often, and exiting Revit fixes it.  And yes, my software is all up-to-date.  This is for LT at home.  At work I use the full version, but I only have 2012 and 2013 installed.  Most of our collaboration is in 2013, and I won't make families in 2014 since I can't use them in earlier versions.
Other than that, I really haven't seen any issues about them not playing nicely together.  I agree, though, that Autodesk should make sure about it for the full versions.  Since they require you to use different versions at times, they should insure that installing one doesn't harm the other(s).  And a shout out from them would be nice, too.
And rereading my previous post, it should be  'I don't think that the full versions of Revit would tax hardware much more than the LT versions.' Other than rendering, anyway.
Employee
loboarch
Message 6 of 10 (1,801 Views)
09-13-2013 06:52 AM in reply to: tarheels09
2012, 2013, 2014 can be installed side by side.  2012 and 2013 need to have the most recent updates applied, otherwise the Ribbon will not display contextural tabs without cycling through the Ribbin display modes.  once updated all 3 will run sisde by side without issue.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
octavio2
Message 7 of 10 (1,778 Views)
09-13-2013 04:13 PM in reply to: octavio2
Jeff, maybe you can top your anwer with the built  number of the latest update for each of the releases, so these could be conveniently checked quickly by reading your post.
Michael.Rybin
Message 8 of 10 (580 Views)
04-22-2014 11:25 AM in reply to: edwin.prakoso
Revit 2014 Update 1 Fails to install because the 'the expected product could not be located', however, Revit 2014 runs fine.
Michael.Rybin
Message 9 of 10 (571 Views)
04-22-2014 11:50 AM in reply to: Michael.Rybin
My root problem is I cannot sign in or render in could - yet I could about a month ago - so I thought installing revit 2014 would work. revit 2014 installs and runs, but i cannot sign in to the cloud and render + revit 214 update 1 fails. Do you have a list of checks or settings for me to review? Also, I turned off virus software and firewall.
David_W._Koch
Message 10 of 10 (532 Views)
04-23-2014 04:07 PM in reply to: Michael.Rybin
Make sure you are installing the correct update.  The update for the Revit "one box" that is part of the Building Design Suites is different for the updates for the individual discipline Revits (Architecture, MEP, Structure).
Revit 2014 (one box) Update Release 2
Revit Architecture 2014 Update Release 2
Revit MEP 2014 Update Release 2
Revit Structure 2014 Update Release 2
David Koch
