Mel - Do you know if they, Autodesk, are working on a 64 bit app, or one
that will take advantage of dual core? It seems funny that Adesk would come
out with a 64 bit ACAD, and then not have 64 bit for verticals of ACAD, that
would take better advantage of more memory allocation. I think the 64 bit
OS has been out for almost 3 years now, if I'm not mistaken.
Cheers Peter.
wrote in message news:5709061@discussion.autodesk.com...
Hunter,
There are many factors that determine Revits performanc, as there are with
any application software.
First, it is not true that Revit does not benefit from a dual core or dual
processor chips. Most systems with dual core or dual processors provide
load balancing to maximize processor through put for any application running
as well as other processes running in the background, such as the OS or
other applications you have open at the same time or operations as printing
or Internet downloads/uploads.
Second, Accurender is capable of using dual core or dual processors for its
operations.
I use a Dell XPS 700 workstation with dual-core 2.93, 4 gigs of RAM with teh
3 Gig switch enabled, an NVidia graphics card with 512 MB of onboard RAM for
each of the dual DVI/VGA ports and a 260 Mb SATA 10,000 rpm hard drive. My
monitor is a 30" Dell flat panel. Approximate cost of unit 11 months back
was $5,500.00.
My largest Revit project file is around 40 Mb and I am never waiting for the
system, but it is always waiting for me. I also bought a 24" monitor for my
HPZD 8000 notebook for dual monitors and even my HP system provides
excellent performance on files up to 25 Mb and is more than adequate on
files up to 40 Mb.
I worksets infrequently, but when I do enable worksets my team is only one
or two others. I use Design Options at the schematic phase a lot, less
frequently during Design-Development phase and virtually never during CD's.
Most of my projects involve phasing. I create renderings, but not walk
throughs in Revit using Accurender. If the project warrants any serious
rendering or animation I use VIZ.
Worksets can decrease performance at your local workstation, because the
assignment of components, views and borrowing protocols are being updated
across the network to each local machine in the background every cycle.
Design Options also can impact performance due to the increased model
components being created in each Design Set scenario.
As I have already stated my workstation performs beautifully and the 30"
flat panel monitor reduces the number of display changes, i.e. zooms and
pans, required to work.
I am running XP Pro and feel Vista is not ready for me, nor am I ready for
Vista. Maybe next year Vista will mature enough to warrant my interest and
I will upgrade my workstation along with Autodesk release of true 64 bit
Revit solutions.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
MasterGraphics, Inc.
