Compatibility revit 2011 to 2010
3 REPLIES 3
joost_lansbergen
1713 Views, 3 Replies
We've recently uprgaded one of our projects from  Revit 2010 to 2011; much to my horror I discovered there's no automatic backwards compatibility in Revit 2011; this means that the builder and engineer are not able to read my files anymore (they both use Revit 2010).
Is there a way to export our 2011 file into Revit 2010 format?
From other posts on this forum I am aware of the workaround via IFC, but this gives me only geometry. While this suffices for engineering purposes, I am however specifically looking for a way to retain the BIM information associated with the file for the construction company.
Appreciate your responses.
Joost
3 REPLIES 3
Unfortunately Revit project files cannot be saved to previous versions of the database, as it is forward moving only.  I have included a video solution with additional information on upgrades and migration below:
Along with this, I have included a blog post which discusses some other aspects of this:
http://usa.autodesk.com/getdoc/id=TS14878114
Along with this, I have included a blog post which discusses some other aspects of this topic:
http://revitoped.blogspot.com/2009/01/backward-compatibilty-or-rather-lack-of.html
Ryan Duell
DarrenP
in reply to: joost_lansbergen
revit has never been backwards compatible
DarrenP
Ryan,
I couldn't use the video as we have no computers with sound cards in our office, but the blogpost gave some insight.
I contacted both engineer and construction company; turns out they also have revit 2011 but hadn't come around/ had the need to installing it. I guess they're just like us; we've had the update for three months now, and the only reason we installed 2011 is that we needed a way to stop this particular project from crashing on us all the time (It helped).
Thanks for your reply!
Joost
