188 Views, 1 Reply
Columns
Hello, i need to design a building in revit, but it has a odd shape. The shape was created with the conceptual massing tool. now i need to add columns but i don't know how. here is a picture of what i need it to look like; the frame (made in sketchup)
1 REPLY 1
subhra_civil
In both Architecture & Structure you will get column option. Now it depends what you want to need to create. Ok. In column option just create column or if it is too much odd shape then go to Structure option > Component > Model in Place > Select Structural Columns option > ok > give a column name > create a column as per your required shape. I think it will be helpful for you.
Thanks & regards,
Subhradeep Sen
kolkata
India
