Revit Architecture
JamaL9722060
Message 1 of 7 (542 Views)
Column-Wall snapping,
542 Views, 6 Replies
10-07-2012 01:26 PM
Column-wall snapping
In the screenshots below, when moving a column, the snap (endpoint) is working from its corner to the corner of the wall, but this endpoint snap doesn’t appear at the corner of the indicated layer of the wall!
Why there is no endpoint snap there?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Valued Mentor
gh_ar
Message 2 of 7 (520 Views)
Re: Column-Wall snapping,
10-08-2012 01:04 AM in reply to: JamaL9722060
Hi You can do it with the Align tool
JamaL9722060
Message 3 of 7 (502 Views)
10-08-2012 12:32 PM in reply to: gh_ar
Many thanks for the help and the screenshot,
Snap is much easier than doing this with “align”!
Why the snap is still weak in the Revit? Snap is as the “soul” when it comes to drawings.
Firefox 20.0,
Kaspersky 2013.
Distinguished Contributor
cvandevere
Message 4 of 7 (493 Views)
10-08-2012 01:25 PM in reply to: JamaL9722060
Place intersecting column grids in your plan at the locations you want. The columns will snap to the grid intersections.
CDV
JamaL9722060
Message 5 of 7 (489 Views)
10-08-2012 01:37 PM in reply to: cvandevere
Many thanks
What such difficult issue to have a snap at that corner of the wall?
Is this problem still in Revit 2013?
Firefox 20.0,
Kaspersky 2013.
cvandevere
Message 6 of 7 (481 Views)
10-08-2012 01:53 PM in reply to: JamaL9722060
I haven't tried to snap column to a wall to in 2013. My work flow is a little different, I place my column grids then add columns then add walls. I can insert walls at corner point or center point of a column if I wnat too.
CDV
JamaL9722060
Message 7 of 7 (455 Views)
10-09-2012 02:18 PM in reply to: cvandevere
Many thanks for the answer.
As you know, many architects don’t start by grids! And thus columns are placed and then centre lines are then set. I’m talking about this case in particular.
I have the impression that the Revit needs a lot of enhancement in snaps.
Firefox 20.0,
Kaspersky 2013.
