Column display
3 REPLIES 3
204 Views, 3 Replies
Column display
I thought that I remember reading a thread somewhere about being able to turn off or modify the display of a column so in plan view it doesnt show up as a big blob. Does anyone remember this or could point me in the right direction. Thank
John Fleming
3 REPLIES 3
I'm not sure why you have a big blob for a column. Check your object style settings. What lineweight is your column cut properties set too?
SD, thanks I was looking in the wrong spot for that. My cut line weight is set to 4, so I can make that a 2 or 3. I thought that I remember seeing a thread at some point, that I can find anymore, that explained how to make columns to only show up as an outline when it is cut. This will certainly make a difference though.
John Fleming
The fill would be based on the material of the column or in 8.0 if it has a course scale fill set, it would display black or grey or whatever it was set to.
