Column Display at Different Display Levels
3 REPLIES 3
chris_pitt
708 Views, 3 Replies
Hi
Does anyone have a quick explanation of how to make columns display as columns in the coarse level of detail instead of just as sticks?
I know I'll have to edit the family but I can see anything obvious to change.
Regards
Christopher Alan Pitt
Frank Shaw Associates
3 REPLIES 3
Alfredo_Medina
in reply to: chris_pitt
Open the column family, select the extrusion > visibility settings, > activate coarse. Now, do the opposite with the symbolic lines, making them Not visible in coarse level of detail.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
when i open the column family's where is the extrusion setting
@robert.noriega
You most likely have figured this out by now, but for any future readers of this thread, you can modify the visibility of extrusions in a column family by:
  1. Edit the family.
  2. Select the extrusion.
  3. On the Modify|Extrusion contextual ribbon tab, on the Mode panel, select the Visibility Settings tool.
  4. In the Family Element Visibility Settings dialog, in the Detail Levels area, check the toggles of the Detail Levels for which you want that extrusion to be visible.
  5. Select OK to accept the change.
  6. Save the family, if appropriate.
  7. Load the family into the project(s) where you want to see the change.
In the out-of-the-box imperial wide flange column family, the extrusion is only set to be visible at the Fine Detail Level.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
