Solved by teslaoutsourcingservices. Go to Solution.
Do not set RGB color code within the color bar of material browser. You need to make an image in Photoshop and apply your desired color in the image. Save that image as jpg file in your system. Now open material browser, click on ‘image ‘bar, browse the saved image and apply it on your material. In this way you can render your material properly.
Using AutoCAD 2016
I used the sun properties menu bar
"Sun Status" = off
"Sky Properties Status" = sky background and illumination
I chose a dark, dark green for the ground color, but when I render it shows up as bright, florescent green. I tried with dark blue and it renders as bright blue.
I tried turning the sun status on and switched sky properties to sky background(no illumination) but that didn't fix it.
