Revit Architecture
Revit Architecture
Active Contributor
0 Kudos
Post 1 of 4
Color mass Floors according to usage
2628 Views, 3 Replies
03-02-2011 01:01 PM
Hi:
I assigned to each mass floor an usage, and my schedule functions well . That tool is wonderful, isn't it?
But I would want to display each usage in a different color, to show my client how I am organizing the building. Is this possible? Mass floors seems not to have a color or material property.
Thank you,
Silvia
Product Support
30 Kudos
Post 2 of 4
Re: Color mass Floors according to usage
03-03-2011 01:48 PM in reply to: ssoonets
You could use filters to assign colors to the floors, based on usage. See the attached file for details. And yes, it’s a wonderful tool!
Hope this helps.
Alan Quinn
Support Specialist
Product Support
Autodesk, Inc.
Active Contributor
1 Kudo
Post 3 of 4
09-16-2013 08:35 AM in reply to: alan.quinn
At the risk of being dumb why does this work for the 3D view and not the level views?  As far as I can see you still end up with the same purple.
Regards
Christopher Alan Pitt
Frank Shaw Associates
Product Support
41 Kudos
Post 4 of 4
06-06-2014 09:24 AM in reply to: chris.pitt
It doesn't look like the View Filter setup on the 3D view has been configured within the Plan Views.
I tested adding the Usage A View Filter (configuring the same overrides), and the color of the Mass Floor then shows up the same as in the 3D view.
Lance Coffey
Post to the Community
New Post
