Color Fill
8 REPLIES 8
Message 1 of 9
giarushton
516 Views, 8 Replies
Color Fill
I am having a problem with my color fill for room areas.  The color is covering some components but not others; for instance, I can see my toilets but my toilet partitions and doors are covered.  How do I fix this problem?  Any help is greatly appreciated!  Thanks!
8 REPLIES 8
Message 2 of 9
try these:
  1. check Visual Style not to be Wireframe
  2. in Properties>Color Scheme Location>to be Background
Constantin Stroescu
BIM Manager AGD
Your Name
Message 3 of 9
giarushton
in reply to: giarushton
My visual style is set to hidden lines and color scheme is already set to background.  Any more thoughts?
Message 4 of 9
did you verified   Phasing ?....maybe that walls are in a different phase...
Constantin Stroescu
BIM Manager AGD
Your Name
Message 5 of 9
giarushton
Hi there, my phases for components showing and covered are set to New Construction and None.  Is there a way to change a phase for color fill?
Message 6 of 9
I 'll make another try.....
Could it be a Filter applied in Visibility/Graphic Overrides for that type of wall ?
For instance - A filter in which  Visibility is unchecked....
Does it happens only in this file?.....not to be a bug....
Constantin Stroescu
BIM Manager AGD
Your Name
Message 7 of 9
The color fill doesn't necessarily have to be in hidden, you can see it in Wireframe too.
Message 8 of 9
narenvangamudi
Check in the properties, if it's set to OPAQUE and change it to TRANSPARENT. See if that works.
Message 9 of 9
giarushton
Hi all,
I appreciate the suggestions but unfortunately none of those options worked.  Are there anymore thoughts?
Thank you to everyone so far!
Rail Community
