Color Fill Legend Sorting Problem
6 REPLIES 6
adam.jw
1123 Views, 6 Replies
Have any of you ever experienced this problem? Where the color fill legend sorts opposite of the actual color scheme?
What did I do wrong? (This is in Revit 2012, by the way)
____________________________________________________
Please give kudos to the MEP Wish List ideas you like, as this will help the Revit development team prioritize functionality additions!
6 REPLIES 6
alan.quinn
in reply to: adam.jw
Without seeing the file it will be hard to know whats going on. Can you post the file to a Dropbox and let me know the link? Thanks for posting.
adam.jw
in reply to: alan.quinn
Yeah. It's Revit 2012. This was after I re-installed .NET 4.0 (after uninstalling .NET 4.5 because the modify ribbon STILL wasn't working with .NET 4.5 after the 2014 products got installed).
I'll post a link (maybe PM you instead?) to Dropbox when I'm back in the office on Friday.
Thanks Alan.
alan.quinn
If you send a PM via this forum add a comment and post so it will kick the case open on my end. Thanks...
Im having the same problem with my current building. It contains 22 rooms which i have grouped in accordance to names but the legend produces different colour patterns than that of the room layout. was there any solution towards this problem?
I got the same problem!!!!!!!!!!!!(revit 2012)
I have the same problem. Did you ever figure it out? Thanks! -Belzercl
