Can you remind how to turn off the color fills on a floor plan, in which rooms have differrent colors, so only the black line work with the white background shows?
That is, temporarly, so it could be worked on, and then turned on again.
Thanks in dvance.
Solved by L.Maas. Go to Solution.
In visbility/graphics overrides under Rooms deselect Color Fill
Louis
Please mention Revit version, especially when uploading Revit files.
Turning off Color Fills in Visibility/Graphic Overrides does NOT disable color fills calculation - it is still calculating in background and freezes the program (Revit 2022). It finally makes even small revit project of 20 Mb size crash. Any other solution to the problem would be appreciated.
It can be set as a Projection/Surface override in Visibility/Graphic Override.
Go to Visibility/Graphic Override.
Select 'Walls' in the Model Categories tab.
override the 'Patterns' tab to set as Hidden
untick the box for Foreground visibility.
