Color Fill - how to turn off
5 REPLIES 5
octavio2
11759 Views, 5 Replies
Can you remind how to turn off the color fills on a floor plan, in which rooms have differrent colors, so only the black line work with the white background shows?
That is, temporarly, so it could be worked on, and then turned on again.
Thanks in dvance.
5 REPLIES 5
L.Maas
in reply to: octavio2
In visbility/graphics overrides under Rooms deselect Color Fill
Louis
Please mention Revit version, especially when uploading Revit files.
octavio2
in reply to: L.Maas
Thanks, Enlint.
revitom
in reply to: L.Maas
Turning off Color Fills in Visibility/Graphic Overrides does NOT disable color fills calculation - it is still calculating in background and freezes the program (Revit 2022). It finally makes even small revit project of 20 Mb size crash. Any other solution to the problem would be appreciated.
peet.kloppers
in reply to: revitom
It can be set as a Projection/Surface override in Visibility/Graphic Override.
Go to Visibility/Graphic Override.
Select 'Walls' in the Model Categories tab.
override the 'Patterns' tab to set as Hidden
untick the box for Foreground visibility.
Neither of these worked for me, am I missing a step?
Rail Community
