Revit Architecture
New Member
0 Kudos
Post 1 of 4
Cloud Rendering
1165 Views, 3 Replies
05-01-2012 01:01 AM
I have the student version of Revit 2012 and I just signed up for 360 Rendering. I installed the updates needed to be able to install the rendering plug-in and everything went fine with the installation. However when I open Revit, I can't sign in to my Autodesk account. I keep getting the same message ovr and over again saying:
"Requested Service Not Available
The Autodesk service you are trying to access is temporarily unavailable.
Please wait a few minutes and try again."
I keep trying after a while and I get the same thing. I don't even get the prompt to type in my username, this happens when I first click 'sign-in'
Any help is greatly appreciated, I really need to use the cloud rendering.
21 Kudos
Post 2 of 4
Re: Cloud Rendering
05-01-2012 08:35 PM in reply to: micaelasm
It may have someting to do the 'Student' Version, though the message appears on your screen is clear that Service is temporarily unavailable.
You should check with local Autodesk Reseller or customer support.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Member
2 Kudos
Post 3 of 4
Re: Cloud Rendering
05-11-2012 06:58 AM in reply to: micaelasm
I'm using the fully licensed version, but had this same issue a while back and was able to resolve it.
SOLUTION:
Check the time listed on your system (eg. your clock). If your time is off, it will not allow you to access this service, or any other that requires a sign-in to Autodesk prior to being used.
Mine was off by about 10-minutes. I reset it and everything worked great. However, I do have to reset the clock every time I restart my computer, but I usually only restart/shut down my CPU once a week.
Hope this resolves your issue.
Luke Ferguson, PE
Win-7 Ult. 64-Bit
Intel Xeon 3.20 GHz
12 Gb Ram
NVideo Quara 2000
New Member
0 Kudos
Post 4 of 4
Re: Cloud Rendering
05-11-2013 12:02 AM in reply to: micaelasm
this solution didn`t work with me please help me !! :smileysad:
