Cloud rendering via proxy
6 REPLIES 6
AndréKnappstein3584
2387 Views, 6 Replies
Hello gang!
Was searching for keyword proxy and did not find a thread covering this already, so here it goes:
We have 8 seats Revit 2012 + 1 seat BDSPrm 2012, all updated to current status.
We'd like to try the cloud rendering features available for that Revit2012 license in the BDSPrm.
Cloud rendering sounds like a key feature for us and we'd probably upgrade more seats to BDSPrm.
Unlike AutoCAD files, from Revit we are bound to use the plugin.
A connection though is not possible. Error message "no internet connection". There _is_ internet connection, of course, but via proxy. Can someone please confirm that cloud rendering works / does not work, when using a proxy?
Proxy username and password are stored in internet options.
André
6 REPLIES 6
Try signing out and then back in
Rick,
thank you for your quick reply.
Sign out *where* please?
Here is what I tried:
a.) no browser session active, start Revit2012, select "online", select "cloud rendering"
b.) firefox session active, signed in to subscription center and cloud rendering, then (online/cloud rendering)
c.) IE 9 session active, signed in to subscription center and cloud rendering, then (online/cloud rendering)
No success!
All I get is a message "an internet connection is required, please connect to the internet and try again", then, after selecting "try again" I get an infinite "establishing connection". I translated the texts from german. see attachments.
thank you,
André Knappstein
IT and Controlling, beta Eigenheim GmbH
See attachment
Thank you, Rick.
But I have of course tried this before. It is just another way to bring up the same error messages.
Obviously, Revit is not reading the information for the proxy from the "internet options".
So, WHERE do I store the username and password and address of the proxy in Revit?
thanks,
André
The following blog posting has information about the use of the CEA (Conceptual Energy Analysis) tool through a proxy server:
Conceptual Energy Analysis Login Through Proxy Servers
http://revitclinic.typepad.com/my_weblog/2011/07/conceptual-energy-analysis-login-through-proxy-serv...
I suspect that the same issue may be occurring with the Cloud Rendering add-in. You can try going through the steps in the blog posting, but replace the CEA URLs with the following:
http://rendering.cloud.autodesk.com/
https://accounts.autodesk.com
https://api.autodesk.com
http://*.amazonaws.com
Lance Coffey
Technical Support Specialist
jagostinhoCT
in reply to: Lance.Coffey
I am getting the same problem.
Could not log in to Autodesk 360 in Revit 2012
Assistant BIM/CAD Manager
Manchester, UK
