clipped corner garage doors
5 REPLIES 5
RoseKlem8300
2867 Views, 5 Replies
How can you make 45 degree corners for top of garage doors?
5 REPLIES 5
nmysorewala
in reply to: RoseKlem8300
can you post a graphic of what you are trying to achieve?
BIMologist
RoseKlem8300
in reply to: nmysorewala
These "clipped" corner garage doors openings are quite popular.  Has anyone ever modeled these in their projects?
You can do it making a new Door Family :
  1. New Family > New Family- Select Template Family > Door >Open
  2. in Elevation View -Exterior > using TAB , select the Opening Cut > Edit Sketch > chamfer the corner as in Image 1 - you can make this parametric so to to can control the angle and length of chamfering ( I recomend this) - Now the opening is as you want
  3. Create a sweep for door frame and an extrusion for the door leaf..
  4. Load the door into project --Image 02 (a roughexample )
Constantin Stroescu
BIM Manager AGD
Your Name
Thanks - I will try that sometime.
For now I may stick with editing the wall profile 🙂
Thanks man it really helped me!
