Revit Architecture
RoseKlem8300
Message 1 of 5 (502 Views)
clipped corner garage doors
502 Views, 4 Replies
02-19-2014 05:35 AM
How can you make 45 degree corners for top of garage doors?
You can do it making a new Door Family :
  1. New Family > New Family- Select Template Family > Door >Open
  2. in Elevation View -Exterior > using TAB , select the Opening Cut > Edit Sketch > chamfer the corner as in Image 1 - you can make this parametric so to to can control the angle and length of chamfering ( I recomend this) - Now the opening is as you want
  3. Create a sweep for door frame and an extrusion for the door leaf..
  4. Load the door into project --Image 02 (a roughexample )
nmysorewala
Message 2 of 5 (495 Views)
Re: clipped corner garage doors
02-19-2014 06:07 AM in reply to: RoseKlem8300
can you post a graphic of what you are trying to achieve?
BIMologist
RoseKlem8300
Message 3 of 5 (491 Views)
02-19-2014 06:15 AM in reply to: nmysorewala
These "clipped" corner garage doors openings are quite popular.  Has anyone ever modeled these in their projects?
constantin.stroescu
Message 4 of 5 (454 Views)
02-19-2014 10:36 AM in reply to: nmysorewala
Constantin Stroescu
BIM Manager AGD
RoseKlem8300
Message 5 of 5 (440 Views)
02-19-2014 11:44 AM in reply to: constantin.stroescu
Thanks - I will try that sometime.
For now I may stick with editing the wall profile :smileyhappy:
