Hi
Why Revit 2013 when the walls are installed on some laptops is clearly visible
How can I fix this
Thank you all
This is your video card. This happens with desktops also. You should be able to downloa updated drivers for your laptop.
I found this the other day to help explain it.
http://revitclinic.typepad.com/my_weblog/2012/04/glazing-appears-through-walls-in-revit-2013.html
